I twisted the crossmember that is right under the transmission oil pan. Went down a steeper drop then I thought it was gonna be offroading. So rocks and such mangled the crossmember. It actually put a hole in the pan. Just from a bolt on the crossmember. I'm wondering how u swap this whole piece out. I have a 1991 explorer for parts. Mine is a 1994 Explorer. Are these parts swappable? Cause some bolts are where rivets are on the other explorer. vice versa.
Looks like u might have to cut it up to get this crossmember off? I'm not sure. It also connects to the wheels, not directly. Like that whole piece that's under the tranny pan.
Just wondering how this should be taken off and if possible swapped out with the parts truck I have. And how long it would take. Thank you.
