burrcor
- December 23, 2008
- Havertown, PA
- 2005 limited
Remote start added - now no cruise
The other day I had a Ford remote start added to my '05 Limited (which I've had since new with 45k on it) The guy who did the job is an authorized Ford installer. When I went to use the cruise today, it did not work at all, no lights, no nothing. I called him & he explained the installation process and stated that he had nothing to do with the cruise. He also said to check the fuse so I read the book and checked the net only to learn (I think) that there is no fuse for just the cruise. I tried looking for info here but can't tie the two together.
It does seem that the installer guy had to be around the brake electrics and steering column for the remote start install
Has anyone had this done and had the same problem?
Or what to check first?
Thanks
I'm no expert by any stretch of the imagination but I'll try and help you. Exactly what have you replaced? Are your brake lights operating properly?
Principles of Operation
The speed control system is designed to maintain a selected vehicle speed between 48 and 200 km/h (30 and 125 mph).
Whenever the system is engaged and active, a speed control set indicator will be illuminated in the instrument cluster.
The brake pedal position (BPP) switch is normally closed to ground. When the brake pedal is applied with the speed control system engaged, the BOP switch closes to battery voltage, putting the speed control in stand-by mode.
NOTE: The speed control module is integral to the speed control servo.
Normally, when the brake pedal is pressed, the speed control module deactivates the speed control system. Under increased brake pedal effort, the deactivator switch, a normally closed switch, will open and remove power to the speed control servo clutch, releasing the throttle independently of the speed control module.
The clockspring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
The inputs to the speed control servo are the:
vehicle speed signal
deactivator switch
The outputs of the speed control servo are the:
speed control indicator
speed control cable controlled throttle position
Inspection and Verification
NOTE: If any concerns are noted with the speedometer, stoplamps, or horn, address those concerns by referring to the appropriate sections before continuing speed control diagnosis.
Verify the customer concern.
NOTE: Any aftermarket modifications, including but not limited to those listed below, may cause the speed control to not operate correctly:
Any wiring or lamp modifications affecting the brake lamp operation
LED brake lamps
Non-factory installed trailer wiring
Radios (speed sensitive, auto mute)
Remote starters and alarms
Lighting and electrical accessory modifications
Visually inspect for obvious signs of mechanical or electrical damage:
Visually inspect the speed control actuator and accelerator controls.
Visually inspect the speed control cable without removing it and ensure smooth cable operation. Inspect the speed control cable connection to the throttle body.
Visually inspect the accelerator cable without removing it and ensure smooth cable operation. Inspect the accelerator cable connection to the throttle body. Also check for cable interference with the carpet, bulkhead grommet, insulation and instrument panel wiring.
Thanks
