KarstRanger
- February 28, 2010
- Mayo, Florida
- '99 XLT SOHC 4WD
My 99 Explorer 4WD has a road noise that sounds like mud grip tires, but the tires are not mud grip. I have switched the tires around to make sure it was not a bad tire causing the noise.
When I go straight or to the left, I get this humming road noise that increases as I go faster, but when I turn to the right the sound goes away.
It happens in reverse too when the wheels are turned the same way. It does not seem to matter if I am in 4 wheel drive or not, or if it is in neutral or not.
I just replaced the passenger side wheel bearing assembly, and that was not it. Possibly could be the other wheel bearing, as it is hard to tell which side the noise is coming from as I feel it in the steering wheel and hear it in the front floorboards somewhere. Does this type of noise that quiets when you turn one way sound like a wheel bearing?
I suspect a U-joint but how can I tell when it won't make any noise when jack the front tires up off the ground - it seems to need the weight of the truck to make the noise. The U-joints (CV joints I have been told) are sealed and I can't inspect them, but I suppose I could take the boots off.
-- Any ideas on troubleshooting this, please?
