2001ExpSport
- July 23, 2000
- Chicago, Il
- 2001 Sport
Ok....I'll try to explain.
For the past..oh....8 months I have had a rough idle. I ignored it for a while figuring it was bad gas. Once it started to get worse I decided to run a few tanks of injector cleaner which didn't help. I ignored it a little more(hoping it was a phase), but it persisted. So I tried higher octane fuel which didn't help, I knew it wouldn't, but I tried it anyway. Last week I got a check engine light, which gave me a "cyl 3 misfire" code. I bought some new plugs and wires, changed them and the PCV valve I had sitting around for months. Still does it! I cleaned the TB and the IAC valve. The only reason the check engine light came on is that the rough idle was really bad, shankingly bad. It is almost as if the cyl is not firing at all. BUT it is, because if I pull the plug it shakes even worse. It will do this up to 2000 rpm and the run smooth. Drives great and smoothly under normal conditions, just the idle sucks my ass .
Now, it's really bad when it's cold, but it does this all the time. It is not specific to engine temp, just the intensity is.
I have had the 00M12 recall done as well as new intake O-rings.
It has 84k, original 02 sensor(maybe the issue?)
Any help is greatly appreciated.
Matt
Matt
