- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Well, while I was working on my front end I let the axle droop too far and broke the vent tube off the front axle housing. I guess I had the hose pretty well secured.
Since I am going into it to replace a pinion seal, ball joints and steering u joints in a bit I thought I would ask what I am dealing with. Is it a pressed in fitting I have to drill out or is it a threaded fitting I should try an easy out on?
