FMExplorer
the original tramp
- February 6, 2000
- Fort Myers, FL
- '99 Explorer EB
Ok guys - I am wrapping up the swap this weekend. Running into a few questions on the brakes/disc/spindle assembly...
What order does everything go together? This is what I am doing...
1) brake splash guard
2) caliper bracket
3) spindle and disc assembly
here is the problem...
disc apparently rubs against caliper bracket. The bracket is mounted so the caliper is more inside than outside
the spindle does not have enough thread to hold both bearing nuts
the hub appears to be locked - even though it isn't installed. This I am guessing is because there is a locker in the front and that is where the binding seems to be coming from.
Thanks for the help guys!
Jon
2) caliper bracket
Jon
