iammattchew
- October 3, 2003
- Belleville Michigan
- 2001 Sport
i want to do that, but why full width D44?
But oh so tempting to get a D44. Theres a 79 Bronco at the JY right now... $90... I really should just go get it...
I did get gas tank and transfer case skids, second set of shafts for the 8.8 and D30, power steering pump from a F150, auto trans cooler from an Ex for a power steering cooler, and some misc stuff.
Also grabbed a set of 8.8 disc brake assemblies, they are very rare and are grabbed up quickly. A 96 had just come in this morning. I'll save them for my next axle upgrade so I can sell my current 8.8 hub to hub to the Jeep guys for big $$$. How does full width D44 and 8.8 sound?![]()
Why do you want a Dana 44 so much?
If you are building a 44, I would go with a 77 or 76 F150 axle. They have welded on cbushing mounts and 1/2" axle tubes like a Dana 60. Then I would cut off the cbushings and weld on some TNT customs Jeep brackets and run your current setup.
I dig your pinned upper arm. Have you ran it with out the arm? I bet you get some serious travel. I know a bunch of guys who run the RE long arm kit without a passenger upper. Same concept as the wristed EB arm. I haven't seen a quick disco upper though. Cool idea.
what do you do for work, and where are you moving to?
So is that passenger coil a super-flex detachable coil?
