dana 20 transfercase | Ford Explorer Forums
ranger driver
byron,n.y u,s.a
89 ranger xlt
i am looking to replace the j-shifter due to it being worin out,did alittle surfin on net but did not find to much i am what some would call internet challenged:salute::D
89 Ranger with a Dana 20 transfer case???
89 Ranger only came with a BW 1350 transfer case
Need a bit more information please :)
sorry bout that has a 5.0 ho(93) c4 trans with a shift kit also if u know about the aod what yr might work
I would keep my C4 trans instead of an AOD but thats just me
The AOD would rob more power and they are really touchy
Keep the C4 or go 4r70w/AOD-E no more input cable
I would contact early bronco graveyard:
http://broncograveyard.com/
for your shifter parts
Sounds like a nice truck! I know it screams, I have a GT-40p 5.0L (300+ HP EFI) in my 88 BII she runs like a bat out of hell
thanks for ur help i will try the site,i have 373 gears in the rear end just seems to run high rpms at 55 or better
thats because your C4 trans is a 3 speed, no overdrive
You need bigger tires!
33's would lover your RPM's at 55+ BUT take away from some of your low range.
Has the dana 20 t case been re-geared?
i dont believe it has,thanks for the "broncograve site" little more money than i thought but what dont cost these days i will look into the gear situation truck is stuck in low range now so i not going far for now
Hes running a Dana 20 t case behind that C4 auto and he said the Ranger is stuck in low range due to bad linkage... so I think he still has 4x4 LOL which means the C4 was converted to a C5 tailhousing or an aftermarket adapter was used to go C4 to D20
welcome aboard
