Darn fuel lines | Ford Explorer Forums - Serious Explorations
Darn fuel lines
Sign of Cobra
Nowata, Oklahoma
1998 Explorer
I.m not getting the point across. I have a 98 ex sport. I also have a 2001ex 4 dr., I am trying to install the 2001 5.0 motor into my sport. Is it simpler to prep the 98 so it is returnless, or prep the motor so it is a return system? Also, what parts do I need to make the 98 returnless, or the motor with a return system? Will the 2001 computer work? I could sure use the help on this because I'm lost
Get a non return pump , swap it in the sport tank and ignore the return line , I made mine a return system but I was also trying to avoid PATS since my 97 didn't have it , its a lot of work and parts
Also use the 01 computer and you will need to swap the GEM its behind the radio , and the PATS stuff , along with the keys , any questions or if you get stuck on something just ask , also look at vroomzoomboom his build thread is pretty thorough,
