houptee
- February 13, 2011
- new jersey
2005 Explorer XLT 4x4 6cyl Automatic.
Problem started a while ago, Check charging system message comes up, and all gauges drop to 0, i.e. speedometer, tach, a clicking noise behind dash can be heard, then if you let off the gas pedal they come back on again.
Put new battery in few months ago and seemed ok but now doing it again. Disconnected batt cables and charged battery for a few hours. No change same issue.
This is a secondary problem to the transmission problems.
Trans had a whining sound like a power steering pump.
It would not go into Drive or Reverse, it only goes into low 1 and 2. I got it up on ramps and dropped pan, fluid was black and magnet was covered in 1" thick sludge. Changed filter, and cleaned magnet and pan, put 5 qts Mercon V. Whining sound is now gone but it still has no Reverse, but now has Drive.
While letting it warm up after trans service, the dash problem started acting up again really bad. If I put it in R and try to increase rpms to see if it will engage the dash goes dead, and engine starts to choke out. In any other gear, engine does not choke out, but dash goes dead and check charging system flashes as you increase rpms.
No idea what the coincidence is with this electrical issue coming back to life after doing a trans filter service.
Anyway it seems like the transmission is shot but would like to determine the electrical issue or if it could be causing the no reverse.
Thanks for any advice!
