With that dismissive treatment from the dealer Ford would never see a single penny for me again. Why reward a company for absolute garbage engineering and zero accountability on a 50k vehicle? Maybe when they’re driven to the brink of bankruptcy by their deplorable business methods they’ll go back to the drawing board and produce something that isn’t a trash can on wheels stuffed with buggy bells and whistles.That's very unfortunate. Have you driven another Explorer with different tires?
I still can't stop staring at my very attractive vehicle and love the way it drives! The multiple bugs and defects not to mention rapid wearing of components that should last at least 5-7 years are disheartening on such an expensive ride.They’re getting worse with every generation. You’ll eventually get a crappy one.
I'm speechless - as noted in the report below from my selling dealerships service team. According to FORD the acoustic issues are a feature, not a defect.
I spoke with my dealership's manager about them possibly replacing 21" wheels with 20" on a proposed future buy and he said that they can't do it. The reason is that when the vehicle leaves the factory, it leaves with a specific build sheet (specifications) and any changes to that would affect the warranty in the event of a claim regarding the changed items or issues resulting from that change.........................................................
I'm working with my dealership to take back or swap the oem wheels/tires for something not 21" and not Pirelli.
Peter,I spoke with my dealership's manager about them possibly replacing 21" wheels with 20" on a proposed future buy and he said that they can't do it. The reason is that when the vehicle leaves the factory, it leaves with a specific build sheet (specifications) and any changes to that would affect the warranty in the event of a claim regarding the changed items or issues resulting from that change.
Pedro,***************************************************************************************************************************************************************
As I indicated in the prior post my brand new 2021 Platinum with oem Pirelli 275/45 R21 had a very harsh ride, very loud thumping/slapping tire noise over road surface joints and imperfections and a deep base rumble under 50 mph especially upon deceleration.
With the aid of member comments and insights on this forum I decided to install winter tires on 18" wheels. The 18" wheel size is available on the XLT and Timberline trims. The oem wheels from Ford are very expensive so I decided to go the aftermarket wheel route.
I installed 4 new Bridgestone Blizzak Winter tires (P265/65 R18) on 18" aftermarket American Eagle rims from TireRack.
The results have left me speechless again!
The vehicle is now almost dead silent over the same road surfaces.
There remains a slight deceleration rumble at speeds under 30 but in general the 65 profile tires (aspect ratio) have vastly improved ride quality and significantly improved interior acoustics. I suspected the low profile Pirellis were contributing to the rough ride and unpleasant cabin acoustics based on input from my local tire dealer and members on this forum. My local Dunn Tire dealer looked at the vehicle but unfortunately could not locate a reasonably priced 18" aftermarket wheels to my liking.
I surmise the approximate 40% increase in sidewall height and the Blizzak rubber formulation is quiet for two reasons. They are not generation noise and they are significantly reducing the transmission of road surface induced vibrations and noise.
Here's a comparison of specs for both tire/wheel sets. The Blizzaks are listed first followed by the oem Pirellis.
View attachment 422621 View attachment 422634
Pedro,
Glad to hear you found a significant improvement. I have been paying a lot of attention to the sounds in my Timberline and I definately have the bass sounds.
It is almost always under 30 mph and ironically the smaller the crack in the pavement the more bass noise is heard. It is bothersome to me, but I have very noise sensative ears. I'm assuming what you were experiencing with the 21 in wheels had to be much worse than what I'm hearing in my Timberline.
We obviously have the same tire size now, but different purposed tires which creates a little bit of a variable.
Are you running these tires at 35 psi?
I have found going lower or higher by 4 to 5 psi with my tire setup has not changed anything.
Interesting point on the aluminum. Just odd it happens at slow speeds. At higher speeds, sounds are nicely dampened in my experience.I'm running 32 psi (cold) in the Blizzaks.
Yes, the 21" oem setup was very loud. The oem 45 aspect ratio tires transmitted/magnified all the road noises. Ford decided to not outfit the explorer with Pirelli's PNCS (noise cancelling) tires. Perhaps that would have helped.
As I indicated I still have a slight rumble when decelerating or with the foot off the gas pedal under 30 mph. I agree the smaller the road imperfection the louder the rumble.
A metallurgist will tell you steel has much better damping effect than aluminum, due to its mass. Damping absorbs vibrations and therefore there is less sound transmission. These vehcles have a lot of aluminum and perhaps that's contributing to the overall poor acoustics.
In reference to the noise you hear when decelerating, do you think it could be the exhaust? I notice my exhaust to have quite a deep rumble to it and I'm noticing that may be contributing to some of the base noise from just deceleration and not road imperfections. But I have the 4 cyclinder engine, If I recall correctly the Platinum get the V6 as standard and so I don't know how much different your exhaust tone is.I'm running 32 psi (cold) in the Blizzaks.
When I start my car in the garage and put it into reverse or drive, the exhaust it quite deep and resonates to a point of being slightly uncomfortable. When I rev the engine, it get a little high pitched but as the rpms get come down, I notice a deep base noise.
