jasonb135
- January 24, 2019
- North Bend, WA
- 1994 Explorer Sport
Dana 35/44 Locking Nut
This Dana 35/44 Locking nut is the perfect component to add to your vehicle to give you peace-of-mind while under harsh off-road conditions. Features: CNC machined from 4140 Bar Stock Tightened using stock Dana 44 nut tool Fits: D35, D44, 10-Bolt Axles, Ford TTB Utilizes proven thread-pinching...
desolatemotorsports.com
So I finally went to put these on using manual locking hubs inner nut and lock washer. Unfortunately the D.M. pinch nut doesn't go past all the threads, so the splined washer and snap ring wont fit on the axle shaft either. So I'm thinking the only way this will fit is with the inner lock nut installed, grind the tit off, install the D.M. pinch nut, so maybe the gap to the splined washer and snap ring are tighter? Also does anyone know the torque rating for the Allen head screws on the D.M. pinch nut. I've emailed them and have got no response.
