Sniperdyer
- July 4, 2020
- New York,NY
- 1991 Explorer 4DR
Desperate need of Overheating advice. So I've been dealing with an overheating issue for quite some time. I had a small crack in the radiator and replaced that. I replaced the water pump, clutch and fan. I replaced the thermostat with a cheap dura last one from AutoZone (I didn't test it in pot with Boiling water to see if it worked.)
I've also replaced the top and bottom hose. I've replaced the spark plugs and wires. I've burped the radiator using a burping kit to remove air. I've done the combustion test with the blue liquid to see if I have a gasket leak and the test passed. The liquid didnt change to yellow and stood blue. To confirm the liquid worked after I placed on radiator opening I placed it near the muffler to make sure the liquid would change color to yellow ( which it did once it picked up the gas).
I have noticed that the bottom hose is not as hot as the top hose. Could this be the problem, but from where? I think I'm going to get another thermostat and replace it , but before I install I'll try testing it in a pot of water. Can you guys recommend which temp I should get? I know stock ones are 190 and up according to Hayes book.
