Boomyal
- December 28, 2013
- Vancouver, WA
- 2006 Explorer Ltd
I finally got a good day and the time to finally do it. The engine compartment on my 2006 V8 had never been scrubbed up. Considering that it had never been cleaned, it wasn't too bad but not up to my standards.
I used Gunk engine cleaner and a bristled scrub brush where ever it would reach. I let it sit a while then used a narrow mist to flush the engine. Then I went over everything with warm water, soap and a scrub brush. I even cleaned the underside of the hood and the sound pad.
Each step along the way, I had my compressor at hand and blew out the spark plug wells so water did not sit in them for more than a few minutes. I assume that there are some semblance of seals that at least try to keep water from getting down to the plugs. As I have never had the coils out I am making a big assumption.
Do you think everything will be good? I didn't want to start the engine right up as I wanted to give time for water to dry that might have gotten in any electrical connections.
