sd_iconoclast
- February 17, 2012
- San Diego, CA
- 1991 Explorer
I have a '91 EB 5 spd with about 175K on it. It has developed some strange symptoms lately. I am hoping one of you guys can recognize them.
I bought this car with about 135K on it. It had a cracked head. I replaced the head with a new one and I replaced virtually everything easily accessible with the heads off. This included alternator, all AC components, fuel injectors , radiator, hoses, water pump, Ignition wires and plugs etc. Then the other head cracked so I replaced it with a new one and replaced the lifters at the same time as I seemed to have alot of valve clatter at startup. This clatter responds really well to rislone, but has not gone away completely.
Recently, the car has developed a tendency to "shuddder" under fairly heavy load. I can get it to happen when I am accelerating and I shift up. It will also happen when I am going up a hill and I need to downshift. It seems like reducing the load will make it stop.
The other day, my son was driving it and experienced one of these "shuddering" episodes but he did not let off the gas. He says he heard a load "pop" and then a backfire. Since then, the oil pressure has been low. It used to idle at about 15 psi at around 700 RPM. Now it idles at between 6 and 9 PSI. I see these pressures on my equus mechanical oil pressure gauge. The factory gauge jumps around quite a bit when I am in the 6-9psi range.
I have also noticed that I now get a noticeable "clattering" noise at about 3000 RPM. But, the car runs pretty well if I just keep it below 3000 RPM and 3/4 load.
I also try to rev the engine at idle to keep the oil pressure up.
Any ideas?
Any ideas?
