Differential bearing replacement | Ford Explorer Forums
300nz
Florida
'99 XLT
Anyone out there replaced the rear differential pinion and carrier bearings themself ? I think the gears are fine but the pinion bearing sounds noisy with my stethoscope.I ordered a bearing kit from Jaws Gear. Any tips would be appreciated as this is going to be next weekends project. Thanks :eek:
I've done a complete rebuild on the 8.8 in my tbird when I changed the gears in it. The bearings aren't that bad to do if you have a press to take off and install the inside bearing on the pinion gear, and on the sides of the carrier. As well, be sure to set the gears up properly. There's a write up on TRS on how to rebuild a diff.
