dacaur2
- March 12, 2018
- eagle mountain
- 2010 explorer XLT
So driving yesterday I started hearing a sound like when your brakes are completely worn down and the metal of scraping on metal. I was quite a ways from home so just resign myself to replacing the rotor when I got home. The odd thing is now and then it would grab and put a drag on the engine for a moment.
Finally something let go or something and there was a horrible grinding so I immediately pulled over and had it towed home on a flatbed....
Pull the tires and the brakes were all fine..... So I have my wife drive it slowly and I think the noise is coming from the differential. thing is it's not always the same noise and it doesn't always make noise driving along slowly.... Here is a video that starts out in reverse then goes to forward then back to reverse again then forward... also I can feel it through the trailer hitch when it makes the noise the squeaks and the klunks.. sorry 4 commentary and inconsistent camera, my wife was attempting to eject me from the rear of the explorer....
Secondly now I don't know if this is related, I was told that no 4th generation that the factory with mechanical limited-slip, but it sure feels like some kind of limited slip in here, or something I never actually did this test before I had the problem so I don't know if it's related or just something else.
One tire off the ground the other one is on the ground, transmission in neutral. if I turn the tire slowly it just keeps turning, but if I turn it fast it will catch and then I'll feel it release and I can turn it some more than I will catch and release then I can turn up some more. in the video I an pressing as hard as I can the entire time when doing it fast, its stopping on its own and I keep pressing. If I had to describe when it releases, its like a valve slowly opening then it will spin some more........ (Edit- after pulling the diff out and opening it up, definitely not limited slip. Seems the pinion bearings are bad. My theory is when rotating slow everything was fine, but when rotating fast it caused the pinion to move and allow the u-joint in the driveshaft to bind.... Doesn't make perfect sense, but it's all u can think of....)
