skrylla
- March 19, 2007
- Katy, TX
- '01 Sport 5-speed
On my '01 Sport 5-speed I've had a relatively difficult time shifting into gears for several years now... but it's been only a mild nuisance until recently. 1st gear has always required a little effort but recently, sometimes 2 and 4 are nearly impossible. For years, if I clutched/shifted too quickly into 3rd it would grind just a bit going in. Suffice it to say there's at least one thing going on.
I'd like to narrow the problem down so I have an idea what I'm in for...
Here's something I've noticed recently that I hope will help in diagnosing: Sitting on level ground with the tranny in neutral, if I press the shift lever toward any gear the truck will ever-so-slightly budge. The most noticeable forward movement is toward 1st, rearward movement noted when pulled toward reverse. It does not matter whether the clutch is engaged or disengaged; the same slight budge is there.
Clutch fluids appear normal. I haven't tried bleeding yet, but I'm guessing it's going to be more involved than that...
Thanks guys----------
