Flow the lines from the small cooler. See where the go. I'm pretty sure its a tranny cooler. On your rear bumper do you have holes to mount a ball for towing. Also try a search I know there are pics posted on this.
Originally posted by GenLee01 On my 94 sport in front of the radiator i have a small looking one. is this stock or is it a tranny cooler or oil cooler? how can i tell?
On the first-gen Exploders, the factory auxiliary automatic tranny cooler will be about 6" high x 13" long and mounted on the driver's side in front of the radiator and A/C condenser. It will have two rubber hoses attached to it that put it in series with the radiator tranny cooler. Trace the rubber hoses back to where they hook up - one should terminate at a metal line that goes to the bottom tranny cooler fitting on the radiator and the other should terminate at a metal line that leads back to the transmission.
First-gen Ex fluid path is transmission to cooler fitting at top of radiator, bottom cooler fitting on radiator to auxiliary tranny cooler, tranny cooler back to transmission.
yea it has a hole in the bumper that i put a convert a ball on it. so i can change sized for the trailers i pull. cool i am glad it as one. now i don't have to add one, lol.
Gimp,
that is exaclty where it is mounted and looks like. cool. happy days, lol
Originally posted by GenLee01 yea it has a hole in the bumper that i put a convert a ball on it. so i can change sized for the trailers i pull. cool i am glad it as one. now i don't have to add one, lol...
Just remember that the bumper is only rated as a Class II, so don't tow anything big with it. If you tow anything over 3k lbs, you should install a Class III hitch.
that is very true. i have pulled my 18' boat on the bumper and a snowmobile trailer with 2 machines on it. i hope to get a reciver hitch this spring before i really start pulling my boat.
while you are all talking about tranny coolers. I was under the x this last weekend to change the oil for the first time, and let me add it was very easy with the oil filter right there, and i noticed a little cooler in front of the oil pan, is this a tranny or oil cooler?
