do we have MAF options? | Ford Explorer Forums
DTDK
minnesota
01 sport trac
So, do we first gen guys have maf options other then stock or C&L.
anyone know if a lightning f150 maf uses the same bolt pattern as our stock MAF units?
What exactly are you looking for? A larger diameter intake MAF housing, if so then check out Zabteck.com, Todd sells bigger MAF housings and T.B.'s.
Wont a 5.0 maf work?
what i am trying to do is get into around a 70mm maf for less then 200, with the 4 bolt pattern which is what they charge at zabtec for the modified C&L MAF
And i was able to find a core to send to Todd for the TB mods, as they are all out of job one TBs
If you build yourself a cai im pretty sure you can use a few different ones, but im not totally sure
i am going to try an 80mm out of a cobra 4.6 and see if i can get it to work
With the 80mm unit you'll probably cause too much turbulance becuase of the mismatched tube sizes. You really won't gain any HP or MPG but it'll sound louder in the intake tube.
