Do you use tap water or deionized water in your cooling system? | Ford Explorer Forums
  • I let my mechanic decide what to put in.
    Votes: 0 0.0%
  • Total voters
    22
wpurple
CT
97 Explorer
Do YOU use tap water or deionized water when doing a coolant add after flushing the system?
I assume that most if not all garages would flush with and use tap water for the cooling system????
deionized water is "slipperier" I think.
Tap. Its not a formula 1 car.... My opinion...
You're right- our Ex's are much more important than that! :D
But I do use tap water too.
Water
All I know is that if you have replaced the radiator, most manufacturers that have extended/lifetime warrantees, require that you use either distilled or dionized water.
Most tap water contains calicum, iron, manganese and sodium cations. They produce salts and corrosion. Deionized (DI) water no cations no corrosion.
Bingo. Having seen what the inside of a water pump and radiator looks like from a life of being fed tap water............I use distilled or DI.
Corrosion is oxidation cause by oxygen. Water contains oxygen, there in lies the problem. Not the cations, anions are the ones to worry about like chloride and flouride ions. Both of these have the possibility to accelerate the rust in the steel or cast iron of the engine and water pump.
Tap water typically contains chlorine. DI water costs about $1 a gallon.
Neither copper nor aluminum oxidizes in the presence of pure water? The damage IS caused by the mineral content.
And if you have any combination of aluminum and copper in the same cooling system, you will have galvanic corrosion even using pure distilled water.
