Since I got my truck it has been like this. Looking at the hinges there doesn't seem to be an adjustment that would bring the door out to match the fender. The truck has never been wrecked that I can tell or was told about. Maybe the fender was removed and never put back on right. The second pic is hard to tell but there is a gap between the plastic and the body. Door seems to be seating properly and no air leaks can be heard. Everything seems to point to the fender but I haven't had the time or weather to crawl under and check the fender mounts. The third pic shows the whole line from straight on, hard to tell since the flash got in the way but the pinstripe line is about a half inch higher on the fender than the rest of the way back. Any way I can fix this if it turns out to not be the fender?
