Door Latch on 03' Explorer | Ford Explorer Forums
traig hicklin
florence, south carolina
2003 ford explorer sport
Hello Fordies,
I accidentally moved (clicked) the door latch on front drivers side to the closed position and now the door wont close and I cant get the latch to open up. Any help would be appreciated.
Thanx
Welcome. What you have to do is put a screw driver against the latch part that moves & hold some tension on it & then pull the inside door handle like you were opening the door & it should pop open. Let me know if it works.
reply
:)Hey, Thank You so much! It worked and I can shut my door again.
