06XLS
- February 18, 2014
- Coos Bay Oregon
- 06 Ford Explorer XLS
I am having trouble with two things though... The remote lock control doesn't work. I bought a new battery and it still don't work. Is there something I may need to do to program it? I tested the old battery and it only had 0.3VDC. I tried to use the remote programming procedure, but it didn't work. I couldn't get the fob to send a signal, or the receiver isn't working. One or the other isn't working. Where can I get a new key fob? Or is there another way to test the fob?
Also, I am having trouble locking the doors with the door lock button on the door panel. I press it to lock and within about 1 second it unlocks again. Not sure what to do about that. I can't lock it. As noted above, the key fob isn't working, and it doesn't have a keyless code entry point. It's an XLS model. I found instructions on pg. 98 of the manual to turn off a autolock feature. I went through the process and it seemed to work OK. Then I drove it again and when I stopped and got out, I tried to lock it and within 1 second again it unlocked. I had to manually lock the 4 doors by hand, but the rear lift gate was still unlocked. I had to leave it that way.
