Although not necessary, your system will sound better if you put crossover to filter out bass singals from F&R speakers because they will no longer be "trying" to produce the lower frequencies they can not. Perhaps you should get an electric crossover that is adjustable so you can fine tune it. Have some bass coming from the speakers also, so that the bass from the sub will "enhance" the sound. If you cut too much bass from them, you'll end up with unnatural sound staging.Originally posted by aldive
When using the MTX Amplified ThunderForm , do you need to use "base blockers" from the 4 door speakers?
If not "needed", will it sound better using them?
Thanks....
Originally posted by tbomb
and loud music does not mean youre going to damage your hearing.
LOUD sounds period DO INDEED damage to hearing,
When installing this sub package, is it recommended to line the area with dynamat? I am concerned about possible vibrations and rattles induced by the bass.
Thoughts and ideas requested....
Take head?!? I'll buy that!Originally posted by aldive
I hope you take head and save yours.
