Door wire harness | Ford Explorer Forums
Door wire harness
Michowski
2002 explorer xls
I have an 02 XLS and am having issues with the wiring between the door and cab. What I want to do is just run a brand new ground cable but I see that I will have to remove a bit of items on the inside around the parking brake. Is there any kind of detailed pictures with how the wiring is routed and what's in the way? I've been googling for a while but I am not seeing anything out there. Any help would be appreciated. Thanks in advance
might help if you indicate what part of the vehicle you are working on. Driver front/rear passenger front/rear or rear hatch/glass?
Drivers side door. Problem with running them with the old is I have no idea where they go without really tearing apart the inside. I don't want to tear things down if I don't have to. I just wanted to know how the wires are routed so I only have to take apart what I have to.
