there are two dpfe sensors. (differential pressure feedback egr) One is smaller and more square, while the other is larger and rectangle as the one pictured above. Neither of which are interchangeable with eachother. Also AutoZone used to carry them but have stopped for a reason that none of them care to discuss. The ford part numbers were 4U7Z-9J460-AA for the square one and 4L3Z-9J460-AB for the rectangle one. These part numbers are a few yrs old as I have not worked in the dealerships for the last 4 yrs but if ford has superceded these part numbers, these will still pull up.The number on your old one is an ID number and if given to your local ford dealership or local parts store, can be cross referenced to the actual part number. As for replacing the EGR valve it's not needed. Keep your old one, remove it and clean it. The chambers get partially clogged with carbon deposits and throw the erroneous code for insufficient EGR flow. You can also get a can of SeaFoam from the auto parts store for <$10.00 and follow the directions for cleaning the carbon deposits within the combustion chambers via your main vacuum line at your power brake booster. Lotsa white smoke outta the exhaust pipe and the possibility of causing CEL to illuminate but you can go to AutoZone and get it turned off.
