Baddecision93
- November 24, 2010
- Orrville, OH
- 92 XLT
Ok...finished my lift & I'll admit I didn't turn out to be terribly proficient at it. But it's done and it looks sweet. But there's still some "rough edges" to smooth out.
First off, I did a 4" Rough Country in the front and spring over axle in the rear.
The front (for the most part) is good to go after an alignment. The back, surprisingly, is giving me problems.
To distill it down, the driveshaft seems short, it vibrates, and I've got a bad brake leak at the passenger wheel cylinder. For more details see below.
Driveline:
Ok, so I ended up having to disconnect the driveshaft from the differential to slide the axle back. I marked the flange and the "ear" of the driveshaft with marking paint but the driveshaft paint came off (Ok, so I didn't use paint, I used a soapstone; rookie mistake I guess).
The driveshaft pulled out of the tube right away so I know it needs lengthened. But aside from that when I got it back in and drove it there was a fierce vibration. I know if I put it back on wrong this could affect it.
My pinion angle is set way too downward so I'm going to loosen my axle u-bolts and try to tilt the axle back and refasten them. If this gets my spline in a reasonable amount forward should I attempt just disconnecting the drive shaft at the diff and flipping it 180 degrees and reinstalling it? (to try to cure the vibration/balance issue).
Also, should my pinion be as close to level as possible? It's at pointed pretty downward right now. My dad has a 2000 Mounty and it's angle isn't perfectly zero (90 degrees) so I'm not sure how exactly it should look.
Brakes:
Ok, I'm pretty sure the passenger wheel cylinder is leaking. I hear a "crunch" or "grinding" from in the drum when I roll the truck. I can probably take apart the drum and figure it out. I'm fairly confident this happened when the axle fell off the jackstand...I made a judgement call for the drum to hit the floor instead of my fingers.
But my REAR ABS light is on, as well as my red BRAKE light.
Now, I cut my e-brake line off (because it wasn't working anyway - very poorly installed previously) so that might be the reason for the red BRAKE light but I wouldn't think it would have anything to do with ABS. I cut it at the back on the driver side of the frame and just pulled it all out, by the way.
I guess my only questions for the brakes are:
Can the e-brake cable being cut affect anything other than the e-brake operation?
Will low brake fluid in the back (due to a leak) cause the ABS light to come on or should I be looking for something else I screwed up?
If you guys can give me any input I'd be forever grateful.
Driveline:
Brakes:
