Starscream88
- December 11, 2004
- Park Ridge NJ
- 96 Explorer Limited
Hi guys,
Im new to the baorad as I have just bought a Explorer, Its a 1996 Explorer Limited V6 with 4WD,
Now the Truck runs great etc etc, Except the Trans seems a little funny,
I have changed all fluids, in the Trans, Transfer case, and Rear Diff,
The Trans fluid seemed fine, I did this first the day I bought it,
I was having this problem where when you brake it seems like the trans shifts down and surges the car foward, I belive its mentioned in another thread it feels like you have been rear ended,
So I decide to change the teransfer case fluid and diff,
Well I didnt even get a cup full of fluid out of the transfer case, And it came out dark brown and didnt smell like ATF at all! Looks like its never been changed since 96!
So I filled it with fresh ATF and obviously filled it all the way,
Didnt cure anything,
When your on the highway at around 50+ I see the Rev counter drop from 2k to 1k and then you hear this huge whining wirring sound and its REALLY loud, Only goes away when you touch the gas pedal again
So Im scared now that my Trans is dead,
also when im in N and select 4WD auto or 4WD low it really clunks going in, Is this normal??
The trans shifts smooth up and down gears, Just seems like the last gear when you are breaking to stop and now the highest gear when you on the highway is screaming until you touch the gas,
Whats wrong with my truck?
Transfer cases and Transmissions are expensive, And if Im going to replace them I want to know which one
Thanks and a hello from the board n00b
