Driver side dash noise tied to speedometer. | Ford Explorer Forums
traveler100
Bradenton, Fl
2019 Ford Explorer XLT
I have a 2019 ExplorerXLT 57K miles that started makeing a noise in the dash near the speedometer that’s starts around 40mph. It sounds like an old worn speedometer cable. I’m not sure the car has a old school speedometer cable. the noise is not a blend door actuator click or the inside cabin temp sensor. It’s tied to vehicle speed and not wind related. Starts at 40 and becomes minimal at 80+ MPH, but still present just a higher frequency sound.
I have a 2018 and it's started doing the same thing. Definitely not wind related. Starts @ 40 mph. Did you ever get an answer to this issue?
Welcome to the Forum. :wave:
The main cause of these noises is either the cowl or 'A' pillar. How did you eliminate the wind as a possible cause?
I first heard it a couple weeks ago but it only made the sound a couple minutes, was intermittent then stopped. Not sure if you are old enough to remember a cassette tape player or not but it almost sounds like an old cassette player rewinding or fast forwarding at a high speed. It only starts at 40+ MPH. You can pretty much pinpoint it coming from the speedometer because it is quite loud. It sounds like a beehive and the frequency/pitch gets higher the faster you go. I have some wind noise issues from the outside of the vehicle and that's not what's going on. As soon as the speed drops to 40 or below it stops.
I had an 8 track player in the 79 Olds I had. I graduated from High School in 1965. I saw the Beatles on the Ed Sullivan show. Does that answer the age question?;)
I believe the 'beehive' noise was used once by a member for the noise a loose cowl would make.
My guess is that the stepper motor that drives the needle is going bad.
I will take a look at that to see if that's whats happening. Thank you and I loved the age references. LOL. You never know these days who's answering you so you don't know exactly what examples to use! 😁
