dasport04trac
- June 19, 2012
- tx
- 2004 ford sport trac
i open it up and i found the rail that the window goes up and down was loose than i saw there were two rebids that holds the rails it broke of i guess from rust so i drilled the rebids to where i can install a bolt and a nut threw it and success now it works fine so given you guys a tip if this happen to you srry i didnt take picture i was in my mode in getting it fix c ya
