Driver's door rattle | Ford Explorer Forums
abdo1234
2013 Ford Explorer Base
Hello guys ....
So , i've got this rattling coming from my 2013 ex driver's door for a while , it's driving me crazy ! ... don't know how to describe it but sounds like plastic getting squeezed , it only appears when driving on a bumpy road , doesn't matter if i am driving in low or high speeds , and if i lowered my window it dissappear and every thing get quite again , any one got the same problem ?
I would think that you would likely have to take the door panel off to find out what is causing the rattle. I'm guessing that something is either lose or rubbing against something. One way to find out if a similar issue has been posted about is to use the Forum's handy 'Search' feature (Upper right). Although there are several threads on 'rattles', non seem to fit your issue. Does the window have to be completely open or just partially to negate the rattle?
Also, please add the trim level (Base, XLT, etc.) to your profile so it shows in the margin. This can be useful info to have at times. Thanks.
