sze kan
- January 10, 2018
- Philippines
- Explorer 2012 3.5L V6
Hi all,
Just noticed that all of my doors make a single rattle noise when it is going over bumps or uneven road. The sound is more like a single "tukkkk" like as if the doors are not jammed in properly ...
I have opened all of them and made sure everything is tight... then I also applied sound deadening on the panels.. However, the sound is still there... it only happens on uneven surface and if Def. Somewhere from the main frame and not inside the door panels...
Do the doors have any rubber stoppers which you can adjust? I have seen some rubber adjusters in the hood and the rear trunk but not on the doors....
