full foot notch
- August 9, 2004
- orlando
- 92 2dr 4x4
guess what boys and girls, i just installed a new ujoint and in the 14 bolt rear
and its sloppy as all hell, so i get to drop the $$ for a 1 ton driveshaft setup, probably a high angle CV driveshaft at that, or would i only have to get the 1410 yoke installed into teh axle tube
good news is that it reaches easily and has slack as far as length wise, but the ujoint itself has a latteral slack of about 1-1.5 inch sideways movement, does not even touch the cap stops, and the ujoint straps dont even touch the caps of the ujoint, by the way, is a neapco 1-0153 , or will i have to do some afro engineering and use the 2 caps from a 1ton ujoint on the axle side, and the original caps from the explorer ujoint
as far as the driveshaft is concerned, its OAL is about 45-56 inches, uses the ford tranny flange up front with a smaller driveshaft tube, and the 2nd part of the driveshaft(since there is a slipshaft) is larger, but runs about 2 inches away from the gas tank sheild, so my concern is that if i go with a 1ton driveshaft tube, its gonna rub against the gas tank sheild since its such a limited space under the truck
so what do yall recomend i do
