dual shocks mounts | Ford Explorer Forums
dual shocks mounts
95offroadx
Palmyra, Pa
91 explorer xlt
ok, Im looking into adding a dual shocks to the front of my explorer.. I know skyjacker makes a kit, but could i make a better shock set up? At school i can use the welding and metal working machines. soo i dont think fab. is goin to be a problem. Should i spend my time and make this custom dual shock mounts? Or does skyjacker have a good dual shock kit?
ill also be making extened radius arms, just as soon as i find some at a junk yard
I just moved this to Offroad Fabrication.
If you want extended radius arms i got some off an early bronco that you can have for 20 bucks.
I would say do the extended rad arms first then run a second shock based on how the rad are is attatched.
I think a more simple solution would be to go with shocks that are adjustable. :D
sn0border88 said:
since when do you go with simple :p
I went with what I felt was the "proper" solution :)
