rocket22
- August 28, 2007
- La Grange, IL
- 2002 Explorer xlt 4 wd
I was at the junkyard and removed a much nicer instrument cluster than mine, and hopefully the odometer works. I tried the solder trick on mine with no luck. In any case, should this just be remove and replace? Is there an issue with the mileage i.e will there be any issues with functioning and what mileage will show. I don't care if it is not the right mileage.
