2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
fuses
Fuse 19 (25 amps) in the interior fuse panel is the power source for the PCM power relay solenoid. Current flows from fuse 19 thru the PCM power diode to the PCM power relay. A black/white wire goes from the PCM power relay to ground located in the left front of the engine compartment near the radiator.
I would pull fuse 19, inspect it and then reinsert it. Then confirm there is battery voltage at both sides of fuse 19 when the ignition key is in ON. Actually, it may not be possible to test it at the fuse panel due to lack of exposed contacts.
