BackBone
- December 21, 2012
- Redlands, CA
- 1997 Mercury Mountaineer
Hey guys, I have a double cardon front drive shaft laying around that I pulled from my mounty years ago when I replace my trans and tcase. The original shaft is a 4 bolt set up with double cardon on the case side. In the swap I ended up with a cv style.
Anyways, is the double cardon shaft the same as a ranger double cardon of the same vintage? Length, bolt pattern, and joint?
Thanks for you input and help.
