Aussie Explorer
- June 3, 2005
- Western Australia
- 98 XLT
Gday guys, just after a bit of advice.
I am thinking about installing a Eaton Posi LSD in the old 8.8 in the explorer as the old Trac Loc LSD is Toast.
What is involved with installing this unit, it’s second hand and has travelled 1000 miles (Buying from member off this forum)
Do I need a new set of shims and axle seals?
How do they compare to the Stock Trac Loc LSD?
I take it my existing Crown wheel just bolts onto this unit and then the Eaton Carrier just slots back into the Pumpkin “Diff housing” where the Trac Loc LSD used to be yes?
Do you think it is worth the effort of swapping it in.?
A Diff Loc isn’t on the cards as I am selling the X shortly but if I can get this unit hear cheaply then I may just do it, Cost to Ship it to Australia and if I need new shims and axle seals will be the deciding factor as if it runs up more than $300-$400 AUS total I won’t worry about it.
Cheers for any input.
