I got the same one as you probably. They come with a few nylon ties. All i can say, is, it is a ***** to do by yourself. I guess you could mount it with screws, but the ties are the neatest, especially if your not taking it off. You don't have to take your headlights off. What I did was, if you open your hood, take off that front plastic part(the thing that you can flip up on the sides, to get access to changing your lights). This should let you get behind your factory grille. What I did was just run the nylon straps through the factory grille, and around those vertical parts(im being very vague here). Now the bottom is a pain, because one nylon strap will not reach, so what I did was attached two of them together, to make it longer. The instructions kinda sucked for this. You may be better off buying your own ties, maybe some longer ones, you can always cut the ends off. Also have someone hold the grille, I held it, and put the straps on at the same time, and it was a pain in the ass. Plus it was cold...If you have any questions, just ask. Good luck
