snafu
- November 26, 2001
- British Columbia , Canada
- '92 XLT 4x4
I need help -911 stranded now what...
I hooked up to a trailer , sat idling for about 10 minutes, went to reverse out , then 92 x died. Thought i was outta gas , but wasn`t.
EEC fuse keeps popping.
where does the EEC go, is there any way to bi-pass the ECC, if i try to start truck without fuse, it won`t, if put larger rated fuse, it burns out ( yikes fire..)
Took off all trailer wiring harness, replaced fuse box, replaced EEC relay, sorta checked all wiring, thought i was good to go, then the same thing happened..Pop blew EEC fuse.
Whats the fuse trick , replace with light bulb to figure out where short is..? How..?
PLEASE i need help , going to see my kid`s tomorrow, have to fix NOW !!
email me at rickstrailers@yahoo.ca
Thanks for you`re help-anyone..?
