96eb96
- October 20, 2004
- Albany, NY
- 96 EB V6 OHV 4WD
The EGR valve works fine from a vacuum point of view, it opens and closes. It is now fully clean.
Here is the issue:
I cleaned the EGR valve, and I noticed (I'm being too observant maybe??) that the cleaner would leak down thru the pintle when its closed. Then I blew air into the valve, and noticed that a very small amount of air would pass thru the EGR valve even when it was shut.
The valve is thourughly clean with lots of carb cleaner thru it. It opens and closes nicely with vacuum.
Is this tiny leak normal or should I replace the valve?
Here is the issue:
