Justin1985
- December 13, 2014
- North Carolina
- 1996 Ford Explorer XLT V8
I recently acquired a 1996 explorer XLT (v8) and have been trying to get it to pass inspection. My check engine light is on and am getting the p0401 code for insufficient flow to EGR. Here's what I've done so far to attempt to remedy the situation.
Replaced EGR Valve (old one was frozen with carbon buildup)
Replaced EGR Solenoid.
I'm still getting the code and am at a loss. When I pull the connector to the solenoid off, I get a vacuum that easily feel with my finger. When I leave the hose covered with my finger, I can hear the RPM's drop slightly. I don't have any real mechanic tools or experience and my brother who's been a parts man for 10 years usually has an answer for me but he doesn't in this case. The previous owner said the issue has been ongoing and nobody could figure it out.
From other posts I've read, the EGR valve should not move while idling but only when up to speed. I've tried revving the engine to get it to move but still nothing. But like i said, I'm a newbie and that may be normal.
Also, I disconnected the small hose from the solenoid to the EGR valve and could feel very little from that. I'm not exactly what I'm feeling other than a slight tickle. Agaoin, that may be normal, I don't know.
When I replaced the EGR valve, there was no gasket or o-ring between the valve and the EGR position sensor but I could see a recessed area that looks like there should have been one. Rock Auto shows the replacement part with an O-Ring. (I found a post earlier that that missing O-ring was the culprit for the EGR valve not functioning properly.)
My last bit of amateur troubleshooting was blowing into the vacuum hose that I could feel suction on (coming from solenoid) while the engine was not running of course, as an attempt to see if I could detect any major leaks in the hose. I was able to pass a small amount of air through the hose but not very much at all. I'm not sure if this is normal. Should I be able to blow into it at all?
I am at a loss as to my problem. I'm leaning towards a missing O ring on the EGR position sensor but I'm no mechanic. Any help would be GREATLY appreciated
