EGR Wiring? | Ford Explorer Forums
EGR Wiring?
Wolfie_85
Iowa
1994 Ford Explorer XLT
So, I looked at my EGR solenoid and realized the PO probably broke the connector that holds the two wires, and used a couple of those slide-over connectors to attatch it to the prongs on the solenoid, which works. But I wonder if they are connected to the correct prongs.
So, two wires, which color goes on which prong? This -might- be what's causing my EGR issues. If I find a proper connector, I'll put it in. I just wanted to see if it's hooked up right.
The easiest way to check is to swap them and see if it gets better. Although, it shouldn't matter, it should work the same either way.
The part that bugs me about doing that is that one is a 12v and one goes to the PCM, didn't want to fry anything. :p If I had a multimeter handy...
