Electric Fan Install Link | Ford Explorer Forums
ipozestu
San Mateo, CA
'98 Sportie
So I went ahead and purchased everything in the link above. The termostat from JEGS was back ordered for a while. When I finally got everything in. I took on the install. It was a pretty smooth install. I was pretty happy with the way that it turned out. It looks stock, I don't seem to have any problem with maintaining temp. It did take a little to tweak the thermostat to where I was comfortable with it. I am wondering about hooking up a secondary relay to the speed sensor that will turn the fan on when you drop the speed just to keep the under hood temp down a bit when you are sitting there. Right now the fan cycles on and off as it needs it. I would rather have the air moving around in there while I'm stopped. Does anyone know if this will work? I'll keep you all informed of any thing else that comes up.
