david4451
- February 9, 2015
- cotabato philippines
- 2001 ford sport trac
This my help anyone considering fitting a 12v cooling fan.
I fitted a Spal 16 inch cooling fan to my ST, along with a Derale adjustable thermostat controller, thus removing the clutch fan.
I wired the fan to function when AC came on as per supplied instructions.
The problems encountered were
1. Supplied 40 amp relay failed.
2. Supplied 30 amp fuse blew.
3. When in traffic AC compressor cut in and out rapidly, as load on alternator varied and rpm went high to low demand in cycles, as fan kicked in and out with AC.
I allowed the computer to relearn fuel trims and AC setting all to no avail. Living here in Philippines the AC is always on and have come to the conclusion that the electric fan set up is not reliable.
I've gone back to the stock setup and all is working fine.
