Electric Parking Brake automatically engages when shifted to park | Page 2 | Ford Explorer Forums
Very interesting. I wonder if parking brake technology has changed over the years?
i wonder, i meann brake compounds have changed, but im not too sure if it prevents freezing. not a brake guru though
The Explorer is parked in a garage - it's a level surface so it doesn't take a lot of brake to hold it but I'm sure the brake is on when the shifter is moved to park - I mean who lets the brake off before shifting to park? Maybe we aren't pressing hard enough to overcome some arbitrary limit set but it's not moving so it should be enough. Obviously not on a hill so that wouldn't affect it.
I really think due to it's very recent manufacture date that it got the 'fix' from the factory.
I've never had a vehicle with an electric parking brake before - it's hard to miss when it sets. And we get the notification that it's set every time we start it.
Are you talking about a 2020 or newer explorer?..
your profile shows that you have a 2007 Ford explore 4.6 V-8
you show that you have a 2007 Ford explore 4.6 V-8
look at the sig. he got an 07 4.6, but also a timberline 2.3
Thank you for noticing - I'm getting this a lot lately.
Yes - I still own a 2007 as my DD and we just bought a 2022 as my wife's DD. You can only list one vehicle in the profile and since I've been on that side for a very long time and that's where I spend most of my time I left the 2007 there and included the 2022 in my sig.
I'll also mention that I was referencing a previous post where the manual says it might set the brake if you aren't holding the brake firm enough or if you are on a steep hill. I should have quoted that post but didn't - I thought it was close enough in the timeline that I didn't need to.
im pretty sure you can just type multiple vehicles, no? i swear ive seen multiple ehicles before. and anyways i just typed in 1998 XLT 4X4 in mine, so i dont see why one cant type 07 4.6 and 22 timberline... maybe im forgetting something? ;)
If you abbreviate it enough you can but the allowed character count is low. I guess '07 and 22' would work but that seems cheap. In the other forum it's important to know if it's a V6 or a V8. In this forum there are also multiple engines and the answer to a question often depends on the engine. So hard to relay the pertinent information in that one space.
alright, now i see... forgot bout that one! sig is the easiest to add tons of info to, i just have the "vitals" in the YMM section, if i ever get a 2nd X, im just going 98 XLT 4x4, 91 XL 4x4, or somehting like that...
Are you talking about this profile ?
nope the sig, look below the message, and above the like button. it reads
2007 Eddie Bauer 4.6L / 2022 Timberline 2.3L
like. how mine says 1998 XLT sohc 4x4 oxford white 31 open coutnry at etc etc... are you on mobile? it doesnt appear so, but i know when i view on mobile i cant see sigs
I’m on mobile
I’m on mobile
thats why. cant see sigs on mobile. if you click on the member however and read their info, then you can iirc! but now i can seee why, yeah the PC version is much better!
I’m on mobile
Try holding the phone sideways so you have the landscape mode and check if the Signature shows up.
The signature does show up when the phone is held sideways.
Yes, the brake technology has changed. Old parking brakes were typically engaged by a lever pulling a cable, and mechanically engaging parking shoes, typically in a "hat" inside the brake rotor for rear disc brake equipped vehicles that operated like old drum brakes. In cold climates, this cable could freeze or corrode over time (along with all the hardware in the "hat"), and result in the parking shoes not retracting correctly under certain conditions or as the unit aged. The basic premise on those was use it all the time or never. Binding often happened when they were used irregularly.
These explorers are equipped with electric parking brakes. There is an electric motor attached to the caliper on the rear brakes. When you pull the brake lever (or now as programmed apparently), you will hear a whirring type noise from these motors engaging the disc brake pads mechanically. Similarly, they retract when disengaged - all using the same disc brakes as used in your day to day braking. The fact it isn't a completely separate system makes it less likely to fall into disrepair from lack of use...
Me, after wrestling with all the rusted out components and frozen cables on the old mechanical systems much prefer the new electric systems....
(FWIW, my 2016 F150 has the electric parking brake and its worked flawlessly...)
I've engaged the parking brake several times but have not heard any type of noise when it is done.
Roll your window down, car off and engage. Can't miss the noise... They sound similar on all the cars I've driven with them.
Or if you can't do that, have someone else engage them while you are out of the car.
It's a cool whirring motor sound for a few seconds. You'll miss it if the radio is on. My 2013 MKZ had the switch near the headlamp switch and was tiny like the size of the window switches. Later on they made it a larger one.
not an X, but subaru w E park brake. engaging it sounds like priming the fuel pump almost.
