sqhurt
- December 10, 2007
- ohio
- 93 sport & 4 door
Well I have a 93 explorer, 4 door, 4x4... Have a few problems here. First off there is a ford alarm on this vehicle. When I use my turn signal (both left an right) they flash faster then normal. When you open the driver door the dome light doesn't come on, but does when you open the other door's.. They lights on the bottom of the don't come on the driver door( need to double check about the others) Don't know if there are lights that supposed come on the cruise controls,driver side window an lock controls or not but if so they don't. Also the 4x4 button doesn't light up or work ( have tried 4 different ones an one that came right out another 93 an lights worked) Was wondering if there is a relay or something that controlled these problems that might be bad cause all the fuses I have checked are fine.. One more thing is it seems as when the truck is off an my cell phone goes off (its a nextel) the parking lights flash for a min or so.. Thanks for any help or suggestions in advanced!!!
