Eletric problem | Ford Explorer Forums - Serious Explorations
Eletric problem
89springer
Wichita,KS
2000 ford explorer sport
I had my left turn signal flashing fast. I had the lefr turn signal on and pull my #10 fuse in my panel and lost all turn signals , A/C compressure won't kick in and my heater don't blow heat. All my fuse's are good. What did I do to my truck. My Hi & Lo beams work, and so do my emergence flashers. Help!
did you check both fuse boxes ? there is one under the hood as well,
Ya, I was told I might of burned up some circuits in my Power Control Module. Cause I lost my A/C clutch & heater to boot. But also surfing on here, I read that there is also a fuse relay under in dash for turn signals & one for the hazards.
