emergency brake prob | Ford Explorer Forums
billybob3358
Chuckey, Tennessee
2001 Mercury Mountaineer
ok so i have a 01 mounty and when i push the gas peddal the emergency brake light comes on and wen i let off of the pedal it goes off anybody got any clue why this just started happin all of a sudden
brake fluid is low. check it. at least thats what mine does.
thanks for the info mine is a little low i will try that and see if it helps
I would check your brakes while you are there. The master cylinder level will drop as the brake pads wear.
